Ana içeriğe geç
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
iPhone stuck in Recovery Mode
Hey all! So, several months ago, my phone started respringing every couple minutes, for no apparent reason. It got to the point where I couldn’t use the phone for more than ten seconds without it going black, so I tried to restart it a couple times and eventually ended up putting it into Recovery Mode. However, when I tried to update it from iTunes, I got various errors telling me that I needed to restore it instead. Unfortunately, I didn’t have a recent backup of the phone, so restoring it wasn’t exactly an option, and you can’t back up a phone while it’s in Recovery Mode. So, I tried to get it out of Recovery Mode to back it up, but it wouldn’t exit. I’ve tried every solution from the Apple website and numerous third-party applications to get it out, but nothing has worked. It’s been stuck in Recovery Mode ever since, with me unable to get my data off of the phone. Today, I decided to try disconnecting the battery to see if anything would change- unfortunately, it didn’t work. Do you have any ideas of what I could try next to get the phone into a state where I can back it up?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
First I would suggest installing a new battery. If iTunes still gives you errors while trying to update I don’t think there is much more you can do except replace the dock connector and charging cable.
If you had a faulty battery for some time it could have filled the space where error logs are stored that is why it is telling you to do a restore. It will not update when the error log section is full.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Sam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 12
Son 30 gün: 19
Her zaman: 462
