Replacing Front Glass ONLY,
How Hot does the front glass have to be to starts to separate from LCD?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The point I was trying to get at is glass only on OLED is nearly impossible because of how fragile it is.
Bu yanıt yardımcı oldu mu?
The pixel 2 uses an OLED panel, which are SUPER thin. Anything with an OLED panel is unfortunately very difficult to do a glass only repair on with a very high failure rate.
So how many degrees C° should I set my LCD separating machine at if it's OLED ?
But it can be done right? Try using cold instead of heat,or would that matter when dealing with fragile OLED screens?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 596
