Ana içeriğe geç
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2396 Soru Tümünü görüntüle
Help ID a pie-shaped leftover part from a GSM iPhone 4 repair?
Hi there:
Recently replaced the screen in my iPhone 4. Everything works great, but I was left with one leftover part that I've been unable to place.
It's a flat, pie-shaped piece of metal, about 0.5cm at its widest point, with a hole in it.
Anyone have any ideas? I've reviewed the other reports of leftover parts and this one doesn't seem to match any of the ones I've seen.
A link to a picture of the part:
http://tinypic.com/view.php?pic=2crodon&...
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi. The triangular washer is a black spacer that is under the Phillips screw near the vibrator. Here's a picture of the spacer. As for the tiny foam block, are you referring to the outer plastic ring located on top of the rear camera's flash assembly?
Bu yanıt yardımcı oldu mu?
Puan 2
7 Yorum:
Well I think i found the piece of foam you're talking about. If you take a look at the picture of the speaker assembly, more specifically on the lower left corner, you'll notice this rectangular foam block. It looks like a brick. Is that it?
tarafından
yes walter this is the block. any idea about the pie slice metalic washer/spacer/contact?
tarafından
Well I'm glad we identified at least one of the components. Unfortunately I don't recall any triangular metallic spacer in the iPhone 4 GSM. Can you take a picture of the spacer?
tarafından
yes, but how do i post the photo to you. it seems to be the same size as the black piece in the Verizon model. All the photos and videos I am able to find show nothing under the 1.9 mm screw at teh bottom of the mother board under the ribbon connector bottom left. triangular with a hole slightly offset from center
tarafından
added a photo, it must fit under the screw as a contact plate between the screw head and the 1/2 circle brass contact point on the MB.
tarafından
2 tane daha yorum göster
Yorum Ekle
My advice, if your iPhone still works then who cares! There are small parts like this throughout the phone that don't actually do anything and are just failsafe's if something does stop working. 99% of the time they are never needed :)
Puan 0
Yorum Ekle
I too have been unable to find where this part actually comes from.
My disassembly of the iphone 4 was all going well until i had to turn the frame over to seperate the screen from the body - that's when the piece fell out. I didnt even notice it in the phone before it fell.
Has anyone worked out where and what this is used for?
Puan 0
Yorum Ekle
I think this part is located under the 1.9 mm screw holding the bottom of the Mother board down. To the left side (from back)just above the speaker assembly. I am not certain but I believe its to aid contact of the screw to the Motherboard. the pointed side goes toward the outside frame and the the narrowest side to the bottom of the phone. The screw makes contact without it, so it will still work.
Puan 0
Yorum Ekle
I've just found the exact same washer during re-assembly of a GSM iPhone 4. I've done dozens of these and never come across this washer before. It's not the plastic washer used near the vibrator on a 4S, this is pie shaped metal.
It was stuck to the adhesive where the battery sits but musty have become dislodged from someplace, but where??
Puan 0
Yorum Ekle
Yanıtını ekle
Patrick Kane sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 2,580
