The car doesn't start
my Citroen c8 doesn't start?
Bu iyi bir soru mu?
With a broken timing belt you will have:
bent valves
damaged pistons
possibly bent con rods
Or just a useless timing belt. Do not try cranking the motor over (might lead to all issues mentioned above). Take it to a capable garage!
Bu yanıt yardımcı oldu mu?
Extremely good advice--you can total a engine with a bad timing belt. +
Insert your car's key into the ignition switch and turn clockwise until you hear sounds from the engine bay.
the timing belt is broken and it damaged the engie
If you have a keyless push button ignition it requires you press on the brake to start. There's a brake pedal switch that performs this function which is a common problem and quick repair.
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 2,082
4 Yorum
Could we possibly get some more information?
Jake Devincenzi tarafından
For instance--does the engine turn over?
rj713 tarafından
the engine doesn't turn over
solomon tarafından
Since you are really not telling us anything about what your car does or doesn't do. Start witht he basics. Do you have any battery power? Do your dashlights come on? Do your lights come on? Do they go dim when you try to start your car? You need to give more info if you want a definite answer.
oldturkey03 tarafından
