Ana içeriğe geç
Lenovo IdeaPad 110-14IBR, 500 GB sabit diske ve 2 MB önbelleğe sahip 15,6 inçlik bir dizüstü bilgisayardır. Lenovo tarafından üretilen IdeaPad, ilk kez Ocak 2008'de piyasaya sürülen tüketici odaklı bir dizüstü bilgisayar serisidir.
How do I get into my disk player
how to open disk player
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
If you have Win 10 installed try the following.
Click on the Windows Start button (left side of Taskbar) and then type My Computer in the Search box, click on the This PC app option that appears. Then right click on the DVD drive icon that appears in the Devices and Drives section and click on Eject option and see the the DVD tray comes out.
If the drive tray does not come out, on some DVD drives there is a small paperclip sized hole in the front of the drive. If you press an opened paperclip gently into the hole far enough you feel it click and the tray will manually pop out far enough for you to grab it and gently pull it out to its’ maximum travel.
If it does open this way there may be a bent DVD disc stuck inside preventing it from opening electrically or the DVD is faulty.
If there was a disc inside, after removing the disc, try closing the DVD drive by gently pushing the tray until it closes itself and then try opening it again using the Eject option just to prove that it is working OK.
If there is no DVD stuck inside then the DVD drive will have to be removed from the computer and inspected as to the cause of the problem.
Here’s a link to the hardware maintenance manual for your laptop taken from this webpage.
Scroll to p.32 to view the procedure to remove the ODD (optical disc drive) from the laptop so that it can be inspected or replaced.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
percy davies sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 1,097
