Ana içeriğe geç
The Lenovo Thinkpad Edge 13 E31 (model number MT: 0250) was released in 2012 and runs Windows 8 from the factory.
How do I replace the Touchpad Hardware?
Hi !
It looks like a touchpad hardware problem.
Windows 10 Device Manager indicates Error 24 on the touchpad device driver.
Is there a Touchpad Replcement guide ?
How can I verify if it is a simple misconnected cable or the device itself?
Although I cannot relate the touchpad malfunction to a previous lab visit (on another issue) it might be a simple issue of not re-assembling a flat-cable or something.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Here’s a link to the hardware maintenance manual for the laptop.
Scroll to p.77 to view the necessary steps and then the procedure to remove the top case assembly and microphone module The touchpad is part of the top case assembly.
If it is determined that the touchpad is faulty on p.114 there are two part numbers (part #3) for the top case assembly.
You may have to check which part number is relevant to your particular model variant. Hopefully it may be stamped under the top cover somewhere.
Once you have worked out the correct part number, if you search online using the part number only in the search term of your browser, you will get results for suppliers.
I didn’t check if it is possible to just get a replacement touchpad without the top cover assembly or not. You may wish to follow it up.
Hopefully this is of some help
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
ameirson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 80
