Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2265 Soru Tümünü görüntüle
Wi-Fi greyed out for few minutes after phone was switched off
Wi-Fi is greyed out only for about 5min after phone was turned off then turned on again, and after that 5min time, Wi-Fi is working as it should be, finding available Wi-Fi’s, have correct speeds etc. Is it mean Wi-Fi IC have to be replaced?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It would be hard to answer this question and I would not accept a repair like this.
My thoughts would be that since the Wi-Fi starts working after 5 minutes you could have a cracked or oxidised pad under the Wi-Fi IC. As the phone gets warm the connection comes back. You could try and test this by applying pressure to the Wi-Fi chip. If that fixes the problem you would just need to re-ball it.
It also could be a problem with your SCL or SDA lines. You would need to check all the pullup resistors.
In older models it was easy to replace the Wi-Fi chip but the 7 is more difficult. Sometimes the pads get pulled from the chip so you need to rebuild them, if you cannot you will have to put a new chip on which would mean unbinding the Wi-Fi address from the NAND.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Ok, understand what you saying but is that module responsible for Bluetooth connection as well? If so then why Bluetooth is working perfectly fine and is not greyed out after turning phone on. Problem is only with Wi-Fi. Can you confirm that the Wi-Fi/BT module is the one right at the top of the motherboard, if so I’ll have look into this by putting the pressure and see what will happen.
tarafından
Yes Wi-Fi module is responsible for Bluetooth as well and it is the one on top off the board.
tarafından
Brilliant, thank you for confirmation. But it’s strange they Wi-Fi is not working as is should be but BT is working fine despite being on the same chip.
tarafından
Glad I could help. That chip has a city of other chips inside as well as fets, caps, filters diodes and resistors. It amazes you when you take the top layer off.
tarafından
Yorum Ekle
Yanıtını ekle
Lukas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 73
