Ana içeriğe geç
Sonos Playbase, siyah ve beyaz renk seçenekleriyle sunulan şık, ince profilli bir ev ses sistemidir. Nisan 2017'de piyasaya sürülmüştür. Model Numarası: PBASEUS1
Playbase not powering on
Is there a guide to replacing the fuse? My playbase will not power on.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Hi, did you finally fix it? My play base is also not powering on and Sonos does not repair it because it’s 4 years old….
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi,
There isn’t a guide on ifixit to replacing the fuse but there are guides on how to replace other components in the device.
These will help you to open the device and locate the fuse, if that is the problem. It may be something else entirely
Sonos Playbase
Usually fuses are located near to where the incoming power supply is connected to on a board.
Be aware that fuses come in all shapes, colours and sizes so it may not look like what you think a fuse should look like.
Just look for a component with a board component designation beginning with F. F= fuse.
If you can’t locate the fuse take some close up images of the power board and post them back here.
Here’s how to do this.
Mevcut bir soruya görsel ekleme
It will also be handy if you have a DMM (digital multimeter) and a soldering iron and you know how to use them both as you may have to prove that the fuse is faulty or not for a start.
If the fuse has blown then there’s always a reason why a fuse blows which may have to be investigated and if it is OK then you will have to do further testing to find out what the problem is.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Calvin Ho sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 1,032
