Dishwasher starts and stops
I have a KitchenAid dishwasher (KDPE234GPS) that will start washing but the pump shuts off after about 2 seconds. Self test shows a code of 4-3 indicating a problem with the wash pump circuit but both the pump and the control board have been replaced. Still has the same problem. The pump starts for only about 2 seconds and then shuts off. It seems to repeat that several times but the wash pump never run for more than 2 seconds.
Bu iyi bir soru mu?
10 Yorum
Hi @sweigner ,
Did you check the wiring between the control board and the pump for any loose or corroded connections etc?
jayeff tarafından
I cut the wires near the control board and applied 120vac to the motor wires to test the wiring and the motor. It seemed to operate normally (pump water continuously).
Scott Weigner tarafından
I have a Kitchenaid KDTE104ESS4 and have exactly the same problem. I've replaced the entire sump assembly, control board, control panel, turbidity sensor and checked all wiring and connections still nothing! Pump starts for a second then shuts off. Repeats several times. Any update?
Unclefudd tarafından
I have the same problem - seems like the pump is switching off after a couple of seconds in cycle. Error codes 4-3 and 6-4 so I just replaced the circulation pump but to no avail. Wondering if anyone found a fix for this? I have a Kitchenaid KDTE204DSS0
Mike tarafından
I hv Kenmore 665.13839K600. Have same problem seems like post start water turn filled.... pump switch off after few sec.when is press cancel buttons pump starts agin and shutdown in Few sec again...u can do this as many times as I want while pressing the cancel button..in the end when I press cancel long time it srauns aater.
Please assist?
Sj sg tarafından
5 tane daha yorum göster
