Ana içeriğe geç
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
382 Soru Tümünü görüntüle
Screen completely dark, external monitor works
I got this iMac used, the previous owner told me the connector to display on motherboard had broken off. I had the connector replaced by a professional repair shop, but the screen still won’t turn on. Not just backlight, the screen is completely off, not even showing in system information. (I tried to shine a flashlight into it, nothing)
If I hook it up to an external monitor, it works as the only display device, so I think the video card is fine..
Now what could be the problem? assuming the connector and display cable are working correctly (I tested every pin with multimeter)
LCD itself? Display power board?
I’d appreciate some expert opinions, thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hi
It seems, backlight is not working.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
If it's only the backlight, shouldn't the screen be detected in system information as a display device? As in, my external monitor should be an extended desktop, instead of the only desktop.
tarafından
Yorum Ekle
What is the tech telling you? Did you or he take any pictures of the damage? If you have pics lets see them Adding images to an existing question
I’m suspecting he didn’t properly install the connector and/or there was more damage where the solder pads got pulled off so there is no electrical connection to the deeper circuits beyond the solder point on the main logic board.
Puan 0
Yorum Ekle
Yanıtını ekle
John Zheng sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 57
