not set brightness LCD
Hi guys
I changed the LCD only. The brightness setting does not work.
only ON or OFF, no brightness adjustment.
Do you know where the error is?
Bu iyi bir soru mu?
Hi guys
Bu iyi bir soru mu?
I’m thinking the cable may have been damaged. Multiple pins carry the backlight power. Otherwise the logic board backlight control has an issue.
Why did you replace the display? If this was a liquid damaged system the connectors or cable could be corroded as well.
Take a few pics of the connector and cable ends so we can see what they look like Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 64
2 Yorum
Can you give us where you bought the display as well as the Apple P/N for it.
Dan tarafından
https://www.replacebase.co.uk/apple-macb...
Tomas Unger tarafından
