Ana içeriğe geç
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 ve Late 2011
Metallic taste from surface of laptop
There is a curious metallic taste coming from the track pad and surface area of my mac book pro.
Has anybody encountered this situation ?
Bu iyi bir soru mu?
Puan 2
4 Yorum
happen with any other equipment? ever thought it could be your electrolytes?
tarafından Paylaş
what was wrong with the answer you received yesterday to this same question? Mayer knows his bickies and I think he has a very valid answer.
tarafından Paylaş
Don't lick your laptop
tarafından Paylaş
I m having a similar problem. Even when using imacs I feel a pinching feeling like pepper in my nose, lips and Metallica taste
tarafından Paylaş
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have your dentist replace your silver amalgam fillings with a composite material. Your metalic taste is most likely being caused by the slight electrical current discharging in your mouth via your fillings. Read up on it here: http://www.drpgilbert.com/metallic-taste...
Bu yanıt yardımcı oldu mu?
Puan 20
5 Yorum:
Didn't know this was possible. +
tarafından Paylaş
I was thinking similar lines re small current/electrolyte problem but more localised, it's a good read.
tarafından Paylaş
+ Hah! I had no idea this was possible. Crazy stuff.
tarafından Paylaş
Did you find the answer to your problem?
tarafından Paylaş
Early in my life I had a dental laboratory and did crown and bridge work, went to lab school for two years.
tarafından Paylaş
Yorum Ekle
Bu cevap aslında başka bir soru için verilmişti.
I don't think it's normal to experience tasting flavors from simply touching an object.
That said, if you are touching an aluminum case and you lick your fingers afterwards, it's possible that you could be licking up some aluminum dust.
Either way, I wouldn't recommend licking your fingers or your laptop.
Puan 5
1 Yorum:
My dog does that for me ;-}
tarafından Paylaş
Yorum Ekle
I would try adding a colloidal minerals supplement in the liquid form to your diet to see if this resolves any mineral deficiencies you may have. Many of the minerals are metals. In chemistry the Theory of Equallibrium tells us that all touching matter exchanges atoms. I would also try washing your hands prior to touching the track pad. Colloidal/Ionized minerals are in the form of salts. Your sweat has salt in it.
Look to see if touching other items brings this sensation. That may help you narrow down the cause of it.
Puan 3
3 Yorum:
that's what I was thinking.. you put it much better than i could.
tarafından Paylaş
I think if you had elaborated on your thoughts Poly that your words would have been more eloquent than mine. However no one seems to view our thoughts as a viable solution to the problem at hand.
tarafından Paylaş
ha ha..at hand! get it? ah well no one else will either. ;-P
tarafından Paylaş
Yorum Ekle
sometimes, when i move myfingers over the metal part of my laptop, both the unibody and the one before, i feel some ‘stick-slip’. it is gone when i unplug the power. clearly, some voltage comes through.
Puan 1
Yorum Ekle
Yanıtını ekle
Michael sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 33
Her zaman: 2,612
