Ana içeriğe geç
Business-grade laptop released in 2009. Model Number: Latitude E5500.
Black Display but computer works
When laptop boots up the computer screen is black and the ONLY lights that are on are the numlock key and Power button. If I hook up an external monitor, it works fine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Just verifying that you pressed Fn +F8 (I think) to toggle between laptop screen only, external monitor only and both on together?
Try shining a torch at an angle close to the laptop screen and check if you can detect an image at all when the laptop is on. It will be very faint if it is there so try this in a darkened room.
If you can see an image then there is a screen backlight problem
This could be caused by a faulty display inverter, a faulty inverter cable connection, or a faulty CCFL lamp.
Here’s a link to the service manual for the laptop.
Scroll to p.25/73 (pdf page numbering) to view the necessary pre-requisite steps and then the procedure to remove the E5500 display inverter so that you can check the connections etc.
If it is determined that the inverter board is faulty, inverter boards are available online, just search for Dell Latitude E5500 CCFL LCD Backlight Inverter Board to get results for suppliers.
If it is determined that the CCFL lamp is faulty, replacement lamps are available online. Just search for Dell latitude E5500 backlight lamp to get results for suppliers.
If you can’t see an image and since the screen is black then there is either a problem with the LVDS cable (damaged in the hinge area perhaps), the LVDS cable connection (at either end)from the motherboard to the display or the motherboard.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
What does it mean when; When laptop boots up the computer screen is black and the ONLY lights that are on are the numlock key and Power button. If I hook up an external monitor, it works fine.
And Thanks a bunch for responding so soon. Its the 1st time I posted question............
Sheri
tarafından
@Sheri Penny Luedke ,
If you're getting a display on an external monitor only then it means there is a problem with the laptop's display.
In the answer above it shows how to check for what may be the problem
Usually there is a HDD light as well but work on the display problem first as the laptop is working with an external display so the HDD (or SSD) is working
Did you try testing the laptop display using a torch or try using the Fn +F8 keys to toggle the displays, you didn't say?
If so what was the result?
tarafından
Yorum Ekle
Yanıtını ekle
Sheri Penny Luedke sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 24
Her zaman: 1,299
