Ana içeriğe geç
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
20 Soru Tümünü görüntüle
motor cuts off when engaging blades
I have a 12 year old 19.5 hp craftesmen riding lawn mower that runs at high and low ideal when no blades are engaged but now when i engage the blades the motor stops running. Changed oil,changed plugs ,changed air filter,washed ,air tires. No luck fixing.
Bu iyi bir soru mu?
Puan 12
9 Yorum
Cleaned everything up around pullys, checked belts and and put all back together only to started it and hear a very high pitched circular squeel in the motor. I'm thinking the motor is going bad. Thanks for all your suggestions. But i'm thinking it's time to take to a pro.
tarafından
Sorry to hear about your engine. Hope everything works out and let us know how it is going
tarafından
I have a craftsman riding mower and it ideals up and down then when you try to engage the blade it cuts off I have changed spark plugs, cleaned the blades, and checked the belt, all is fine I need some suggestions on what I should check next I was going to check to see if the fuel solenoid is bad that it's not getting enough fuel to operate the blade but not sure please help thanks and God bless
tarafından
It may be a bad spindle bearing that is seizing up when you engage it which puts too much load on the engine and makes it die. You may hear some squealing sounds from the spindle and the belt may smoke. Most all these spindles can be taken apart and you can easily replace the bearings. I replace mine every couple of years. Get them by sets of 10 on Ebay really cheap. Make sure you leave the spindle on the deck when you remove the spindle shaft because often the brittle aged attachment bolts will snap off if you try to remove them. They are very hard to drill out. You can leave the blade on the bottom of the shaft after taking the big top bolt off. Then put a new bearing over the shaft bottom and then add the spacer sleeves and push the shaft through from the bottom. Put top bearing on tighten nut. On some Craftsmen like the Troybuilt TB 30 MTD equivalent they have a safety switch around the deck shoot and if that is not positioned right or goes bad the engine will die when the blades are engaged.
tarafından
It could also be a bad battery. One bad cell is enough to not let the fuel solenoid work properly when the mower blades are engaged.
tarafından
4 tane daha yorum göster
Yorum Ekle
8 Cevap
Filtre ölçütü:
Seçilen Çözüm
Turn your mower off and check how the blades turn underneath the deck. Any obstruction, damaged pulley shaft, or seized pulley can be the cause of that. Check your belt and make sure it is properly routed and that it does not get hang up at at of the belt guides. Remove the pulley covers from the top of the deck, and check to make sure that he belt and pulleys are properly functioning. I also think that there is a possibility that your mower may have a safety interlock system that prevents the mower from engaging when there is no operator. So check on the safety switches, I believe it to be on the seat. as well as on the parking brake. This of course is only valid if your engine is properly running, that the idle is high enough and that the engine still has enough torque to deal with the mower deck. Good Luck and I hope this helps.
Bu yanıt yardımcı oldu mu?
Puan 15
12 Yorum:
+ I think you about hit it all oldturkey. The only thing I would add to that is some of them also have a safety switch that will kill the motor if it is gear when you attempt to engage the blades. The transmission speed lever needs to be in P and the High, Low, Forward, Reverse lever needs to be in N when the blades are engaged. After the blades are engaged you can put it in gear and it will run.
tarafından
You're a genius! It never occurred to me that you had to have everything in neutral before engaging the blades. I've been trying to figure out why my Mower kept cutting out when the blades were engaged. Thanks again
tarafından
Safety switch under the seat loose
tarafından
wish I had looked this up before I bought that new front pulley..thanks save me a bunch of money though..
tarafından
@tananxa
tarafından
7 tane daha yorum göster
Yorum Ekle
Definitely check wiring and all switches, starting from the ignition switch, behind the panel.
Occasionally over the past year my John Deere Sabre would be difficult to start, and more recently every time I would fully engage the PTO lever for the mower deck, the engine would die.
$500 in parts and labor later (carb, plugs, fuel pump, fuel filter, battery) I discovered that the wiring harness/plug behind the key on/off switch was loose.
When bumped slightly by the PTO lever engaged, it would loosen and engine would not restart until the loose switch/plug settled back into place temporarily.
Another sign that it was loose wiring or a switch should have been that sometimes the engine would die while rattling around over a bump, even without the PTO lever engaged.
Puan 3
2 Yorum:
I've checked everything the problem is easy to see when I engage the deck one cylinder quits firing why is what I can't figure out
tarafından
Seat switch is bad, so it's telling mower no one is seated on mower, kills fire to engine, safety feature in case someone fell off or overturned mower. Most likely is the problem.
tarafından
Yorum Ekle
I find it to be the safety switches being the culpret, check for out of positition, debries interfering with it, its not nessarily the switch , the can be pricey. if certain conditions are not met, trying to engauge the blades will cause the engine to die.
Puan 1
1 Yorum:
You can take the switch loose. And use a wire and Jump it and if it runs then you know you're switch is bad.
tarafından
Yorum Ekle
When the mower deck safety switch is working correctly - you can engage the blades and the mower will not die. Well if that switch isn’t getting pressed or depressed correctly by a rotating piece of metal connected to the engage wire or in my case, it’s all metal pieces - I have a SABRE and there’s a rod with a spring on it - that rod that goes through the spring will get out of circle and wear out to an oval shape. well there’s a shape like this [______] now imagine a spring and washers on the inside of that on both sides - well how the bar stays inside of that - there is two little bumps - well once that metal bracket thing is worn to an oval that bar will go right through - so there is NO spring action - that spring action is just enough to put pressure on the switch - when there’s no spring action, that switch can not get pressed. When you go to start the blades and your mower is running fine but it dies when you start them - that button is not getting pressed in all the way - due to that slack - and it will kill the engine. Now that rod and spring may be just fine - but there is a nut at one end - adjust that nut in or out - that rod is threaded. You may need just a bit of an adjustment to get it to push that button in all the way. - due to the places on the deck it mounts to and so on getting a bit out of wack or just wear and tear over time. This is the answer to the problem - bar none. Personally - I got sick of hitting bumps or going on hills and the mower dying so I bypassed every stupid switch. Lots of tutorials on youtube and online.
And Bob's Your Auntie.
If the mower runs just perfect until you go to engage the blade - this is the issue.
WARNING - IF YOUR MOWER DIES WHEN YOU GO TO ENGAGE THE DECK./BLADES - YOUR ENGINE STOPS GIVING SPARK - SO YOU WILL HAVE A HEAD FULL OF GASOLINE ON TOP OF THE PISTON (S) - BEFORE ATTEMPTING TO START - REMOVE THE SPARK PLUG (S) AND HAND CRANK THE ENGINE A FEW TIMES - IT WILL SPIT THE GASOLINE OUT OF THE SPARK PLUG HOLES. - REPLACE SPARK PLUGS AND YOU'RE SET AFTER YOU MAKE THE ADJUSTMENTS NEEDED OR REPLACE THAT BAR./SPRING DEAL.
IF YOU DO NOT DO THIS - YOU WILL BE STARTING YOUR MOWER - AND YOU WILL BLOW THE ENGINE - MOST LIKELY IT WILL BREAK THE PISTON ARM (S) AND POSSIBLY THE CAM (S) - DO NOT BE THAT GUY!
Puan 1
2 Yorum:
What if the mower dies when releasing the parking brake ?
tarafından
Gotta be a safety switch.
tarafından
Yorum Ekle
Had same problem with my Hustler Fastrak. After cleaning carb, changing fuel filter, air filter spark plugs I still had the problem. I realized that it only stalled under a load. I decided it was a weak fuel pump. After replacing the fuel pump it works like a champ. Probably needed to do all the other things anyway. Hope this helps.
Puan 0
Yorum Ekle
When I had this problem, the engine only stalled when cold. It turns out the problem was a blown head gasket (a common problem with a Briggs and Stratton engines)
Puan 0
3 Yorum:
To be more specific, the small hole in the head gasket reduced the engine power just enough that engaging the blades overwhelmed it and it would stall.
tarafından
how do you diagnose it? Oil leaking?
tarafından
There was a small oil leak: You could see by the exhaust that it was burning a little oil. The problem was that it passed compression tests; so I kept looking elsewhere. Eventually I ran out of other options and decided to replace the head gasket anyway.
tarafından
Yorum Ekle
remove gum from gas deposits in carburetor ad to gas tank gum remover
Puan 0
Yorum Ekle
I've changed the carburetor coil seat switch blade engaging switch and I still have the same problem new spark plug but my mower runs great until you engage the blades can anybody help me thanks for any feedback
Puan 0
Yorum Ekle
Yanıtını ekle
david sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 32
Son 7 gün: 223
Son 30 gün: 707
Her zaman: 167,209
