Ana içeriğe geç
McCulloch MC1275, çok çeşitli yüzeyleri temizlemek ve dezenfekte etmek için 93 °C'nin (200 derece Fahrenheit) üzerinde ısıtılmış normal su kullanan, ağır hizmet tipi bir hazneli buharlı temizleyicidir.
Steam machine won't heat up.
When I turn on the unit, the light goes on but I don’t get any steam. I thought I put to much water in it. So I emptied unit started over, and still no steam. Is it possible the heating unit burnt out and is it something I can replace?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
Same problem
tarafından
water heats up ,but, no pressure or steam comes out.it work just minutes before..pouredcontents out ,red rubber substance came out.tried to clean as per instructions. [nothing changed] was this red object a washer or something else ?????
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Do both the Power On/Off light and the Steam Ready light come on when you switch the cleaner on? Not quite sure if this is what you meant when you said”… the light goes on….”
If the Steam Ready light doesn’t come on it may be a heater problem or perhaps a thermostat problem
If they both do come on try clearing the machine of any buildup of mineral deposits to see if this resolves the problem
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Still not working
tarafından
For future ref: there's a thermoresistor thats placed on the side. If that goes out, u can try & find a replacement or at ur own risk leave it out. Caution, if u don't know about thermo resistors than u r not experienced enough to do this procedure. I took out all cut-out power items with the lines running direct to heating elements. This is not adviseable only to responsible enough not to leave machine unattended while plugged in use. But the machine still works. You got to be aware of the machine blowing the hose if your not aware the signs this machine works. And plugging & unplugging after every blast.
tarafından
Yorum Ekle
Yanıtını ekle
baschilz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 4,116
