Ana içeriğe geç
Repair guides and support for tablets made by Hipstreet. These tablets run on the Android OS.
71 Soru Tümünü görüntüle
Whch charger for hipstreet pilot.(quite old)
Anyone know actual size for hipstreet pilot 10”. Its few yrs old and us a thin round charger with a yellow tip if this makes a difference. Mine has snapped. Just wondered size before i buy wrong thing. Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Here’s a link to a supplier of the charger.
It shows that the charger has a 5V DC / 2A output with the plug size of 2.5mm. (this is the inner diameter measurement, the outer diameter is 5.5mm)
Check electronics stores in your location for plugpack adapters having the same specifications. The voltage/current output specifications should be printed on the adapter. You may have to verify the plug size as there is a similar looking plug with a size of 2.1mm that is often confused with it (2.1mm inner diameter and 5.5mm outer diameter)
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
mandswarren sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 88
