Ana içeriğe geç
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
How to fix loose display connection?
A few weeks ago, while I was leaving my MacBook Pro on the table, it blacked out on itself. At first, I thought it was just running low on battery so I charged it. Then I noticed the backlight is still on, the keyboards were also lighting up. I suspect the display connection is loose. Is there any way to fix it or do I need to replace it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum
So, I checked with Apple Support, turns out my macbook is not eligible for the service program, it was meant for the 2016 model, mine happens to be a 2017 model.
tarafından
@jkai03 - Don't give in! Apple will replace it but you'll need to push!
The phone support folks are programed to say no! Going directly to an Apple Store and pressing will get you a yes!
Here's the details on FlexGate: The Design Flaw Behind MacBook Pro’s “Stage light” Effect!
tarafından
Okay, thanks again!
tarafından
So, I am answering this question myself for the sake of people having the same “Flexgate” issue like I do. I got it fixed by Apple, with zero charge. And here’s how I did it.
First of all, “Flexgate” is something that Apple technical Support Team will NEVER acknowledge. I called the technical support team five times, and I got the same answer 5 times…. “Your only option is to get it fix with a out-of-warranty charge….”
I decided to call Apple’s “"Customer Relations” Department instead. The guy granted me a “one-time-exception'“ to repair my out-of-warranty MacBook after I have convinced him that my laptop should be included in the 13-inch MacBook Pro Display Backlight Service Program. Although I was expecting to be granted a “CS-code”, but I didn’t get that anyway.
I am not very sure how these “CS-code” or “one-time-exceptions” work, but I’ll let those who knows comment under this post.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I know there is a recall or extended warranty on these or similar models due to a bad LCD cable.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Yes! Here's the details of the extended warranty program 13-inch MacBook Pro Display Backlight Service Program
tarafından
Thank you so much, I’ll look into it.
tarafından
Yorum Ekle
Yanıtını ekle
Jie Kai Teo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 2,202
