Ana içeriğe geç
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 Soru Tümünü görüntüle
Charging problem, but powers on
Hello! I have an old first model 3DS and I’ve been having an issue with it lately. Basically, the system won’t charge at all. I’ve tried several charging brick, but none of them worked. However, if tbe battery pack is charged, the system would turn on. Have you guys encountered this problem?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
It’s not the baterry. I’ve tried it on another console and the battery works fine. I believe it’s the fuses. I wanted to know what replacement fuses I couls use.
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Well seeing as it’s roughly an 11 year old system, it sounds like the battery needs to be replaced. All batteries whether in a TV remote or a car, they need to be replaced. You might be able to find one at Walmart. Avoid eBay, Amazon, Craigslist, Wish, and AliExpress, especially if they claim to be an “original” battery as most of the time they’re used batteries from dead consoles. Part number should be CTR-003 but I would double check your system.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Puan 0
Yorum Ekle
Did you ever get a solution to this problem? I'm having the same issue..
Puan 0
Yorum Ekle
Yanıtını ekle
Mereu Lorin-Alexandru sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 48
