Ana içeriğe geç
Nintendo DSi'nin Mart 2010'da Kuzey Amerika'da piyasaya sürülen daha büyük versiyonu. Çoğu onarım işlemi yalnızca bir tornavida ve ayırma aletleriyle gerçekleştirilebilir.
charging socket is broken can it be replace?
can the charge socket be replaced on the DSI XL?
Bu iyi bir soru mu?
Puan 2
2 Yorum
Uh how much will it cost me to pay because the place where you plug in the charger into the ds it won't charge for a second
tarafından
Uh how will I get my ds to you
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
kathy, follow this guide to remove your logic board Nintendo DSi XL Anakart Değişimi you should find the power connector soldered onto the logic board. a new connector is available at places like this. Use a soldering iron to remove the old one and re-solder a new connector. Make sure you do not use to much heat to lift the solder pad. If you are unsure about doing it yourself, find somebody like a TV?Radio repair shop and see if they can solder it for you. Inspect the logic boards for any cracks, or other loose components. Good Luck.
Bu yanıt yardımcı oldu mu?
Puan 6
1 Yorum:
+good answer with sound advice
tarafından
Yorum Ekle
yes go on nintendorepairshop.com or google dsi xl charge socket and they will show you. you send your ds in and they fix it for 54.99
Puan 1
1 Yorum:
or how about he gets the parts for a few pennies, fix it himself and safe some money:-)
tarafından
Yorum Ekle
http://www.ebay.com/itm/DSi-XL-Broken-Po...
Puan 0
Yorum Ekle
Yanıtını ekle
kathy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 6,405
