charging socket is broken can it be replace?
can the charge socket be replaced on the DSI XL?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
kathy, follow this guide to remove your logic board Nintendo DSi XL Motherboard Replacement you should find the power connector soldered onto the logic board. a new connector is available at places like this. Use a soldering iron to remove the old one and re-solder a new connector. Make sure you do not use to much heat to lift the solder pad. If you are unsure about doing it yourself, find somebody like a TV?Radio repair shop and see if they can solder it for you. Inspect the logic boards for any cracks, or other loose components. Good Luck.
Bu yanıt yardımcı oldu mu?
+good answer with sound advice
yes go on nintendorepairshop.com or google dsi xl charge socket and they will show you. you send your ds in and they fix it for 54.99
or how about he gets the parts for a few pennies, fix it himself and safe some money:-)
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 6,047
2 Yorum
Uh how much will it cost me to pay because the place where you plug in the charger into the ds it won't charge for a second
Carlos Vale tarafından
Uh how will I get my ds to you
