Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Soru Tümünü görüntüle
Soru Kapandı
iPhone 3GS After Battery Replaced Problem
I've replaced the battery to my iPhone 3GS because it was getting old and after i put it all back together like its suppose to but when i pull it up to charge, the symbol is different. It looks like a plug instead of a bolt to charge and it looks like its charging but its not could it be just the dock connection? Might of damaged it while i was prying out the battery but doubt it because I've already made calls on and haven't been told that they couldn't hear me or breaking. Can someone please help as soon as possible please i really need to know.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
check connector 4 is in place..it might be only partly on..
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Does it show up on itunes? If not, your usb cable may be bad. Try another usb cable if possible. Also, dock connector might be dirty or broken. Clean the dock connector. If another cable does not charge the device, replace the dock connector.
Link to a new dock connector: iPhone 3gs Dock connector
Link to new usb cable (if you can't test with other one): 30 Pin To USB
If any of these don't work, your logic board may be broken.
iPhone 3GS Dock Connector Görseli
Ürün
$19.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I had similar experience, when I replaced my old battery, the replacement battery didn't want to charge... only displayed bolt signed even after an hour charging. What I did I put my old battery back... and seems the problem solved. In my case, I am sure the replacement battery was bad.
Another step you migt want to try, before you ask or buy another battery replacement or don't wanna use your old battery, is connect your iphone to iTunes on your computer. Check whether you can see anything shown on your iphone other than bolt sign like charging...etc.
One more tip, anything you want to do with opening your iPhone front casing make sure you peel off the three connectors (1 to 3) carefully and gently...they are very fragile, expecially connector number 1... if that tiny black connector detached from its cable ribbon, it's gonna cost you more...replacing the LCD or digitizer.
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 2,034
