Ana içeriğe geç
Model A1199 / 2, 4, or 8 GB capacity
85 Soru Tümünü görüntüle
nano is on but wheel function not working
My nano is fully charged and on but the wheel is not wroking. I press on menu or play and nothing happens. I tried to reset it by holding down the menu and select buttun but it did npot work
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First try restoring it on iTunes. but if that doesn't work, it's very probably it is bad hardware. Try replacing the clickwheel (and headphone jack/case assembly) but if that doesn't do it, it's a bad motherboard.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
screen unlock system rebooting and taking off the code.
Puan 0
1 Yorum:
Would you mind putting this into a complete sentence?
tarafından
Yorum Ekle
Repair on my screenlock chromatic code 2generation code.
Puan 0
1 Yorum:
Would you mind putting this into a complete sentence? Instead of starting a new answer please just comment under your first one.
tarafından
Yorum Ekle
I had my 2nd gen nano, which I locked up on me. I used to workout with it and think it was moisture that caused it to seize. I put it aside in my closet and didn't touch it for a year. I fired it up just recently and it works as good as new. If this happens to any of you I recommend trying to demoisturize it by buying some silica and putting it in a ziploc bag.
Good luck
Puan 0
Yorum Ekle
Yanıtını ekle
fran sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 6,073
