Ana içeriğe geç
The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
Replacement fan is not working
Last night I replaced my Switch’s fan with one received from iFixIt. After closing the system and powering it up I thought it sounded a little too quiet. I gave it a few minutes and the fan never seemed to spin up. I took the back cover off, not the plating, so I could see the fan while the Switch was powered on. It wasn’t spinning at all. I took everything apart and put the old, extremely loud fan back in and that fan spun up as it should, albeit quite loudly. I tried re-seating the cable for the replacement fan and that did not help. Did I simply receive a defective fan or is there something else I should check or be concerned about?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @aaronw630
Since you mentioned you swap the old fan and it works,
Contact Ifixit, most probably the item is DOA
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
how we can fix the switch for the fan
tarafından
Yorum Ekle
Puan 0
Yorum Ekle
Yanıtını ekle
Aaron sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,180
