Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
Shuts off if not connected to power
I have successfully swapped out the logic board on my MBP with a solid part from the iFixit store. It seems to be working great except for when I unplug from my Thunderbolt Display and work without power adapters. It works for about 5 or ten minutes then it will lock up. I’m planning to open it back up and triple check (because I already double checked) the power to the board. But I wanted to see if there was anything else I should be aware of before doing that. SMC, PRAM, Apple Diagnostics all came back fine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This does seem really strange, have you tried swapping SSDs with a known working machine? I had a mac that was doing that same thing once without the thunderbolt display, and it turned out to be the SSD failing on me. I recommend you back up your data as soon as possible whatever you might do, as it’s near impossible to get data off a dead SSD.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Joseph Salmond sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 59
