Ana içeriğe geç
Dell XPS M1730 (model #DYCWM92_6) ilk olarak 2007 yılında üretilmiştir. Birincil olarak oyun dizüstü bilgisayarı olarak kullanılır.
Upgrading HDD to SSD
I have a 500g hard drive (250 each) and want to upgrade it to 1TB SSD. Do I have to use 2X500G SSD’s or can I use one 1TB SSD for the upgrade? What kind of software can I use to migrate the HDD to SSD?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @manjulad .
I assume that you have one 500GB HDD that has two partitions of 250GB each or did you replace the optical drive with a HDD so that you have two HDDs?
Here’s the service manual for the laptop.
Go to p.15 to view the necessary pre-requisite steps and them the procedure to remove the HDD.
Here’s a link to just one supplier of SSD and RAM for your laptop. It shows that you can install up to a 2TB SSD in the laptop. The link is only to show you the cost and what is available. There are other suppliers that may suit you better.
Usually with the supplier mentioned above, they also supply instructions and software (Acronis True Image - download online when product reference number supplied) to transfer the data.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Dissanayake manjula sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 569
