Ana içeriğe geç
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
3GS SIM card reader issues
i have 4 iPhone 3gs’s with this exact issue. i tried to put the board into another housing to sell, and it no longer will read sim cards correctly. when i insert a sim card, It says No SIM in the top left, but sometimes will have carrier settings and phone number show up in settings, but those take over a minute to show up.
if i power it off and back on with the sim card installed, it will say Searching… and continue to say that even if i remove the sim card.
They all used to read sim cards perfectly before i removed the boards, but no longer will in the new housing or when i put them back into the original housings.
There is no way i damaged all 4 of them when removing from the housings/putting into the new ones. doesn’t seem to be an issue with the 2 gold bars at the bottom of the reader or the 6 gold sim card contacts.
Also, the one i’ve been messing with will now say No service, then says no sim card installed about 15 seconds after i take it out, but won’t recognize the sim being re inserted until powered off again, then it just repeats.
if you have any ideas of what the issue possibly could be, or if you need more info or photos, please let me know. thank you
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There arw 2 things you have to check first there is a small coper strip on the logic bord right down under that have to touch the metal frame of the backhousing (step 12 at the possition of the yellow square) :
iPhone 3GS Logic Board Replacement
and second check the simcardreader if the micro switch is working when simcard is inserted.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Looks like your first suggestion was the issue, most of them were bent up and didn’t fully make contact with the housing. Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
Donny sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 560
