Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
Screen reflector problem after sanitizer went inside of iPhone
I was trying to disinfect my iphone with sanitizer i was confident that phone is water resistant and it will not harm my phone but sanitizer managed to get into the display assembly and whole display went blue but after few days display is fine but i have few bright spots like pressure marks and i think its due to impurity managed to get into the backlight reflector in display so cleaning backlight assembly and cleaning reflector will solve this problem or not iam not sure i need guidance please help …
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
I doubt you can clean it. You can replace the screen for about 20 to 30 dollars for a high quality screen if you change it yourself. If you change it make sure to watch a few repair videos on YouTube and make sure you disconnect the battery before you take the screen off or you could short cut the backlight circuit or damage something else. And the phone is supposed to be water resistant but the phone may have been opened before and not resealed. You could also have a crack on the screen. I always put the cleaner on the rag and then wipe the screen. You can purchase a new screen from ifixit and if it's out of stock I also use fixez.com for my parts. I hope this information helps.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Maybe your iPhone has been repaired and as you know after repair of any apple devices the waterproof guard is not working anymore. It happens because of the hermetic substrate which is deteriorated after a service. I'm saying it because I have an Iphone 8 plus and I disinfect it with arcreef sanitizer and I don't have any problems, it is working perfectly.
Puan 0
Yorum Ekle
Yanıtını ekle
gauravdhami60 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,105
