Logitech 510 Mouse does not transmit to computer.
The mouse does not transmit to the computer and the “invisable optic” light does not light up.
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Try a new battery and check the connections on the battery and make sure the battery is facing the correct direction.
Bu yanıt yardımcı oldu mu?
I tried that--problem is that the LED on the bottom does not light up, and I disassembled the mouse, inspected it, and can not find any obvious issues.
Thanks
Anything else you can suggest?
My guess is you need a new mouse. If none of that fixes it.
One could try re-pairing to the dongle through the Logitech Unifying Software.
And the “invisible” optic should be indeed invisible.
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 436
