Ana içeriğe geç
Smart fitness watch via Bluetooth, released in March 2016. Model: FB502SBUL
20 Soru Tümünü görüntüle
Getting the blaze battery sent to Canada
The battery in my Fitbit Blaze is toast and I need a replacement. However, I live in Canada and the battery replacement sold by iFixit (IF384-000-1) cannot currently be shipped across the border. Does anyone know where I could find one of these in Canada?
Replace a 170 mAh battery compatible with the Fitbit Blaze smartwatch. 3.7 Volts (V). Görseli
Ürün
Fitbit Blaze Battery
$19.99
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi @alenux ,
Does your original battery have a 6 digit code number on it at all? The number gives the dimensions of the battery
The convention with batteries is that the 1st two digits are the height of the battery in mm and there is a decimal point between the two digits which is not shown, the next two digits are the width in mm and the last two are the length in mm, e.g. 252020 = 2.5mm H x 20mm W x 20mm L
If so try searching for (insert 6 digit number) 3.7V LiPo battery that has the same or better capacity i.e. mAH.
If you can’t find an exact match try for one a bit smaller in size, especially height, as it has to physically fit into the watch.
Just ensure that the voltage (V) is exactly the same as the original, as the capacity (mAH) only determines the length of time that the battery will last before needing a recharge.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
The numbers listed on the battery don’t seem to correspond to the size. I see:
LSSP321830AE
5C30 46159
Looks like the dimensions for this battery (including the protection PCB) are 1.8 mm x 2.9 mm x 0.3 mm. The original battery claims to be 167 mAH, but all the replacements I see are 120 mAH unfortunately.
tarafından
@alenux
OK,
Maybe you could try one of these suppliers and see if they ship to your location.
tarafından
Yorum Ekle
Yanıtını ekle
Alex Naylor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 81
