Ana içeriğe geç
Xiaomi akıllı telefonu tamir kılavuzları için *doğru* yer.
1696 Soru Tümünü görüntüle
Xiaomi Mi 9 Screen Replacement Lines/Faulty Touchscreen
So this phone has been dropped in water. I opened it all up, screen and everything included and let it dry for a month. Tried turning it on and whilst the touchscreen worked (I could feel vibration from entering passcode) the LCD display was completely busted. I ordered a new screen replacement and tried it initially, everything was working amazing when I hadn’t yet put the phone together. I then proceed to put everything together, securing the battery in with double sided tape but apart from that, nothing out of ordinary. Now after powering on the screen has vertical lines through it (See image). Also only the left side of the touch screen works properly. This is completely bizarre to me. Could it be static electricity causing this problem? Any help would be very appreciated and I am more than happy to provide more images.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@sadphonenoises could be a bad display assembly. Possibly so is that this is left over from the water damage. You said you let it dry out but did not say you cleaned it and checked it. This could easily be corrosion damage/component damage because of the water immersion. You do want to go ahead and clean everything on the inside of your phone Use this guide Repairing iPhone Liquid Damage to do so. It was written for an iPhone but the cleaning is the same as it should be for your phone. After that, re-evaluate.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Alright I will give this a shot. Do you know if Xiaomi has similar water damage stickers that I can determine which sections have been exposed to water?
tarafından
Yorum Ekle
Yanıtını ekle
sadphonenoises sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 367
