Tiny Red dots on my display
Hello,
I have a U32H850 Samsung 4K monitor and suddenly red dots are showing up all over the place. I took the case off and reseated all but one cable (was worried I might damage it) with no luck. Can anyone guide me on what part may have failed that is causing this so I can order a replacement?
Bu iyi bir soru mu?
Hi @tnerb11
Does altering the red colour adjustment in the monitor's Settings improve the picture, you didn't say?
jayeff tarafından
@jayeff No, adjusting the red from 0 through 100 results does not mitigate the issue.
Tnerb T tarafından
Is this only on your taskbar? If so, try changing themes and see if it persists. If it's only on that portion of the screen, it's not a hardware issue.
Chappy tarafından
Hello, I experienced the same, having 2x U32J590 display connected to my laptop: One of them was showing those annoying, fluctuating red dots over dark areas. Then I realized, that that panel was connected by 2 ways - both Display Port and HDMI. When I disconnected the DP cord, the issue disappeared.
Michael Janeček tarafından
I had this same issue with HDMI going into a display port adapter, just unplugged HDMI from adapter and plugged it back in and the problem went away
Tom Garabedian tarafından
