Ana içeriğe geç
Repair and disassembly guides for Mixers.
KitchenAid speed control lever is stuck
The speed control lever on my KitchenAid Artisan is stuck. I have found some videos on replacing parts. Is it likely that some part is broken, or could it be that the problem could be solved by just opening it following the videos and trying to loosen or tighten something? Any suggestions? Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Take a look at this Service Manual which applies to the Artisan (in addition to the models listed):
++http://www.kitchenaidparts.eu/documents/...
You will, most likely, have to open up the mixer to fix the problem. Do not remove the brushes as they can be tricky to replace in the proper position.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
helmer.aslaksen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 43
Her zaman: 6,102
