Ana içeriğe geç
2010 yılında piyasaya sürülen, 15,6 inç ekrana sahip genel amaçlı bir dizüstü bilgisayar.
Sound system is broken
My laptop sound won't work. I've disassembled the device and I strongly believe there's a problem with a diode or transistor, and since all sound hardware seems to be on board, I'm probably going to need to replace some of these small parts. Does anybody know of the schematics for this laptop?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi,
If your computer is not making any sounds, see the Acer Aspire 5253 Has Volume Control Problems problem page for possible causes and solutions.
Here are the schematics for the motherboard, found from this website.
Go to p.27-28 to find the audio circuits.
Have you checked that the headphone socket is OK and connected properly?
When headphones are plugged into the laptop an internal contact in the headphone socket signals the audio codec IC on the HP_Plug# lead (see p.28) to switch the audio away from the main speakers and connect it to the headphone socket. It may be that the headphone socket is faulty and that the audio output is being permanently directed to the socket but it just doesn’t get through it to the headphones. Worth checking first anyway, if only to eliminate the possibility.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Gabriel Bozza sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 501
