Washer will not drain through the drain pipe.
So my washing machine hasn't been draining properly for over a week. I noticed it wasn't draining to the main pipe which goes outside. It does however come out of the small black drain pipe at the front.
Things we have done to resolve this
*Removed the pump filter, removed anything in it (there were coins, fluff etc)
- Checked the pipes and they are clear
- Put back together , still didn't work.
- Checked the sump pipe , I couldn't remove it but I removed some bits from it eg twigs, coins.
- Tried running it again and it still didn't work.
My issue is the water is coming through the sump, into the filter and only coming out of the thin black pipe at the front, which indicates the sump is fine, as the water is going to the filter but only going through the thin pipe at the front. Does anyone know why??
Bu iyi bir soru mu?
Hi @joannewaite ,
What is the make and model number of the washing machine?
jayeff tarafından
Wmb1772s beko
Joanne Waite tarafından
Hi @joannewaite
Please verify the model number as there are no results online when searching for Beko WMB1772S just in case any parts are necessary?
jayeff tarafından
Wmb71442s beko
I don't know and can't give you a confident answer because I'm not an expert in this area, but that happened to me too. A year ago, just before the Easter event, my washing machine started doing this. I got scared because it could explode any moment and I was about to have a party at my house those days.
willjarchif tarafından
