Ana içeriğe geç
Lenovo IdeaPad Y500 is a gaming laptop, manufactured in 2013. The Lenovo IdeaPad Y500 is similar to the Lenovo IdeaPad Y400.
Laptop LCD Compatibility with a cheaper one
Hello,
I have a Lenovo Ideapad Y500 with a bad LCD. The OEM one is a mode LP156WF1 (TL)(C1), however, the LP156WF1 (TL)(E1) is way cheaper. The only difference in the model is the E1 at the end.
Anyone knows if they are compatible? Thank you
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @guacaquico ,
According to this LP156WF1-TLC1 compatible model list they are not compatible. This is backed up by the LP156WF1-TLE1 compatible model list.
Looking at the panel specifications in the links below there are some differences between them, but the LVDS pinout (which is important) isn’t shown so you may have to get the datasheets for each panel to find out if you want to pursue it further.
These links will get you the datasheets but you have to register with the website to be able to download them. Scroll down the webpage to find the datasheet download section.
LP156WF1-TLC1
LP156WF1-TLE1
You may be able to source a cheaper panel using panel model numbers from the 1st list. Just a thought.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Wow, this is such a great answer. Thanks a lot man
tarafından
Yorum Ekle
Yanıtını ekle
Juan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 158
