Ana içeriğe geç
Samsung Galaxy S6 Edge+, Galaxy S6 Edge akıllı telefonunun daha büyük bir modelidir. Şarj sorunu
Why wont it turn on?
my samsung hasnt been able to turn on when i left it charging and woke up in the morning. I have tried everything such as holding the 3 buttons and nothing has happened. it would only stay on 0% battery icon and do nothing, i have booted in recovery mode then it would shut off instantly and go on 0% again. then after it went tonot turning on at all. i replcaed battery and left it charging and nothing too.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Does the charging icon appear though?
If not, maybe it's the charging port.
I am assuming you checked your charger already.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Try using a wireless charger to see what’s up. If it charges just fine, try using the cable. If it doesn’t take a charge on the cable, it’s most likely the charge port, which is a common failure on devices with MicroUSB. The bad news is if it is the charge port that’s bad, you’ll need to replace the screen as well because the two buttons on the side of the home button are part of the port assembly and go under the screen. Unless you can find someone who’s good at microsoldering they can replace it.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Mike Hawk sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 353
