Bose SoundLink mini keep loosing connection to Bluetooth
Speaker is loosing connection to Bluetooth on phone
Bu iyi bir soru mu?
Puan
0
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 93
Hi,
Have you tried another BT signal source device to prove whether the problem is with the phone or the speaker?
How far away from the phone is the BT speaker? BT usually only has an effective range of ~33' (10 Mtrs) depending on what may be in between the two devices e.g. concrete walls can limit the range
If the problem is with the phone and not the speaker, what is the make and model number of the phone?
jayeff tarafından
