Ana içeriğe geç
Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
20 Soru Tümünü görüntüle
Horizontal lines appear on screen, after heating up.
Hello,
Lately, my MBP has started showing horizontal lines at the bottom on the screen. These lines don’t appear during a cold start. They start appearing if I run a CPU intensive task and the laptop starts heating up. Once I shut down and let the laptop temperature drop the lines disappear. If I continue working, as the laptop temperature rises the lines increase as well.
Cold start: No problem
Within 30 mins: Lines start to appear
Another 30 mins: They get intense and start spreading upwards
The display is perfect when I connect to an external monitor. So the GPU seems ok.
I had this issue last year as well for a couple of months, one day it magically disappeared. It has now reappeared, a couple of days back.
Any help is appreciated. Thanks.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sadly you have a known issue with the newer 15” models as well as the 13” Fn system as both have undersized cooling for the system so the T-CON board which is sandwiched between the cooling fins and the heat sink over heats! This degrades it.
At this point you need a new display assembly! MacBook Pro 15" Retina (Late 2016-2017) Display Assembly and here’s the guide to put it in MacBook Pro 15" Touch Bar 2017 Screen Replacement
As to how to prevent killing your new display, you’ll need to get a good thermal monitoring app like TG Pro as you want to push the fans harder when you are running something that requires more CPU or GPU load.
You also want to make sure your fans are not choked up with dust as well as the system as a whole. And make sure you are not blocking the vents or place your system down on a surface which has loose fibers which will clog up your fin areas of the cooling system.
Replace a display compatible with the model A1707 late 2016 to 2017 Retina 15" MacBook Pro laptop. Includes the 2880 x 1800 15.4" Retina LCD Screen, Display Cover, Bezel, Camera. Görseli
Ürün
$507.99
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks for the prompt reply @danj. Is it possible to replace the T-CON board if as you say, that is the affected component?
tarafından
I wish that was possible, sadly its not. The cables are soldered onto it and its just not an available part (new).
tarafından
Yorum Ekle
Yanıtını ekle
Mandeep Singh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 1,469
