Ana içeriğe geç
22 Eylül 2017'de satışa sunuldu. Model A1863, A1905 olarak tanımlanıyor. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Altın, Gümüş, ve Uzay Grisi renklerinde satılır.
873 Soru Tümünü görüntüle
What is the size of every screw in the iPhone 8?
Doing a housing swap and stripped 2 screws (managed to get them) that i need to replace. I have a spare set of iphone 8 plus screws, i just need to figure out what size they are.
i do not have calipers or anything to figure out size with, just my eyes.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It’s hard to know exactly how long the screws are without anything to measure them with.
What I would do is to take the stripped screw and compare it to the other screws, start by removing the ones that are obvious, then removing by length etc. and then you should end up with a screw of the right size.
Hope this helped and good luck! :D
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Yeah had an old iCloud locked + water damaged SE, just eyeballed various screws on that until I found some that worked. Funnily enough, one of the original iPhone 8 screws would not go back in, as if it was too short! But I found some from the SE that fitted really well.
tarafından
Yorum Ekle
Yanıtını ekle
Caitlyn sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 308
