Ana içeriğe geç
Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794 Soru Tümünü görüntüle
Optical Drive Installation problem?
I dropped my lovely macbook pro and the optical drive quit working. I ordered a new drive from powerbookmedic.com and put it in but its not working. Is there any setting I need to change or software I need to change?
Bu iyi bir soru mu?
Puan 1
2 Yorum
Just how is it not working? Did you format it and install a system?
tarafından
All I did was plug it in, I need help with what I need to do to format and install it. Also, I mistyped that, its the OPTICAL drive, not the HARD drive.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi Jordan,
If it is the optical drive that you are trying to replace, is shouldn't need a software update in theory. Perhaps there is something else wrong, or there is a problem with the new optical drive.
To test wither or not it is the new optical drive that is broken you probably should contact your supplier and see if they can exchange it for you and try again.
Or you can get SATA Wondercable plug in the optical drive and see if it runs.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Jordan Filbrun sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 1,279
