Ana içeriğe geç
A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 processor. Released March 19, 2019.
78 Soru Tümünü görüntüle
Will power button from 2017 work on 2019 iMac?
We snapped the power button cable. We’ve done this before on 2015 iMac and we were able to solder the cable together and reseat the power button with no issues. My question is will a power button from a 2015 iMac fit into a 2019? I gauges the parts and wire and they look identical to a T: screw holes, cable placement, etc
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The power button is a simple blister switch which shorting the line to ground, just like the MacBook Pro’s (2015 and older) keyboards do.
As far as compatibility between the 2015 and 2017 cases. You’ll need to tell us if the mechanism fits.
Do keep in mind the leads are different lengths in some of the series as they take different routes.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Thanks for the prompt response Dan!
We are attempting to place a 2015 power button from a 21.5” iMac into a 2019 21.5” iMac.
The mechanism in the 2015 power button is the same (identical) in the pics as the 2019 one we removed. Do you think it’s worth a shot? I don’t see why it wouldn’t work if the parts are identical but wanted to be sure.
tarafından
We you slipped a ringer on me as you marked the system as being a 27" model. I don't think that changes anything though ;-}
You'll still need to make a direct inspection of the button shell to be sure between the two cases. Use a heat gun to soften the glue (don't melt the wires)
Let us know how it goes
tarafından
Yeah my fault! 21.5”
Based on your response it sounds like the function of the button is the same; hence it will work as long as the wire reaches the MLB and the button fits in place.
tarafından
@danj Just wanted to let you know as well as make this answer public; the power button from the 2015 iMac worked on the 2019. From what I see 2012-2019 iMacs seems to have the same mechanics and length of wire. Thanks again for the feedback
tarafından
Yorum Ekle
Yanıtını ekle
Ted Teske sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 159
