Ana içeriğe geç
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
Removing 128GB SSD From MacBook Pro 2017 into a Reader?
Hello everyone,
Recently my wife spilled some some water onto her MacBook Pro and it won’t turn on currently.
Is there a way to take the Apple 128 GB SSD and place it into an enclosure to read it on another mac by any chance? Or, can I use MacBook Pro can I swap out the drive get her items off?
We both have 2017 Macbook Pro 13” systems. I tried searching for a case but didn't see it.
This is the drive I took out:
https://imgur.com/a/PJyPifZ
Thanks!
Bu iyi bir soru mu?
Puan 0
2 Yorum
Try to look for a reputable independent repair shop in your area, they usually have means of transferring data. Might be easier than finding an enclosure.
tarafından
Thank you for the reply as well! I’m going to swap out hard drive from her mac to my Mac @pomikoli
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@antdogs - Sorry to say there is no adapter cases to hold this version of Apple SSD.
If you both have the exact same system (both are function key models) then you could swap over the SSD drives. Before you do make sure you’ve made a backup of your systems data as well as create a bootable external drive as you may needed it to salvage your wife’s drives data.
Follow this guide first steps (1 ~ 15) MacBook Pro 13" Function Keys 2017 Battery Replacement
Then disconnect the left Speaker unit and remove it which is just in front of the SSD Drive, Peel off the tape from the drives case and the logic board connector and remove the two screws holding it in (I would mark your wife’s drive with a sharpie marker so you know which is which.
Follow the same process on your system. Reverse the procedure installing your wife’s drive in your system and hopefully it starts up. If not use the external drive you have setup. Good Luck!
Bu yanıt yardımcı oldu mu?
Puan 1
9 Yorum:
Ahhh thank you! I was looking through for hours and did not see any adapter/external reader like i do with my esata hard drives. I already took the hard drive out of her computer, I wanted to be sure if there would be be any conflict if I put her hard drive in my machine. I will try this today and boot up her hard drive on my machine and copy items over.
thank you very much!
tarafından
@antdogs - Let us know how it goes!
Don't forget to score the answer and accept it if you if are up and running!
tarafından
I definitely will! One more question both of our computers aren’t encrypted, so when I boot up her machine it will be like her computer turning on correct?
tarafından
Yes, it should! You will need to use here user account and password to access the files.
tarafından
Awesome thanks so much! I will do that today and let you know!
tarafından
4 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Anthony Thornton sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,490
