Ana içeriğe geç
Samsung'un tam kablosuz Galaxy Buds+ kulak içi kulaklıklarına yönelik onarım ve söküm bilgileri. Şubat 2020'de duyurulmuş ve piyasaya sürülmüştür.
Galaxy Earbuds Plus Battery Replacement
One of my earbuds isnt suddenly working, so I decided to open both of them to switch their batteries. Turns out, the battery of one of the earbuds isnt working anymore. i want to replace it but the batteries available here in ifixit is only for the galaxy earbuds. i need the plus one. Anyone here knows where i can buy one?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
At 59 seconds into this video that battery type number for the Earbuds+ can be seen.
It’s a ICR1454S coin cell battery.
Searching online using the type number only gets results for an ICR1454 battery not the “1454S” .
I don’t know if they are the same or not but this Varta coin cell datasheet (see p.32) gives the specifications for the ICR1454 battery. There is no mention of the ICR1454S. Perhaps it is a later type.
Check what type number is printed on the battery that you have and search online using the battery type number only to see if there are any suppliers.
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
The Verta Coin Cell should work fine. I am assuming the s just stands for the Samsung variant, because the under side of the battery in the Ear Buds has an edge coating which might act as an insulator or a guideline.
As long as the size, contact (+/-) areas, type (Lithium Ion), and voltage (3.7v) are the same the battery should work.
tarafından
Yorum Ekle
Yanıtını ekle
Carl Jenry Chua sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 44
Her zaman: 1,886
