any advice on fixing a broken 3.5mm audio jack?
I bought 2 Lenovo 300e Chromebook for my kids, and now one of them has a broken 3.5mm audio port. I’m trying to use it with an external headset for distance learning, and the headset speakers work, but not the mic. Any suggestions?
Bu iyi bir soru mu?
3 Yorum
I have just had one of these in , the socket is very easy to remove with a standard soldering iron and solder sucker. Just need to found a replacement socket now.
Glenn Allen tarafından
It looks like you can order them off ali express. The closest one I can find is 5pcs/lot Audio Combo Jack Connector for Acer Ausu Dell HP Lenovo Laptop Headphone Microphone Port , PCB to Top H 1.8mm
https://www.aliexpress.com/item/32614729...
I will check what else i can find and let you know what I got to fix it in the end.
Thank you Glen!
mike tarafından
