Ana içeriğe geç
The HP Envy dv7t-7200 is a notebook complete with a touch pad as part of the Envy dv7 series, released on the market in 2012.
How do I remove the bezel from the display?
How do I remove the bezel and trim around the display? I already have it removed from the notebook. I just need to get to the inverter underneath to test it. There appears to be a screw under the bezel near the hinges on each side holding it in place, but I cannot seem to get to them. I know if I apply any more pressure I’ll break it. I’ve already used a heat gun and I know it’s not glued on. Thank you.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
Here’s the maintenance and service guide for the laptop, taken from this webpage.
Go to p.93 to view the procedure to remove the bezel from the display assembly.
Hopefully this may be of some help.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Thank you! Yes, I assumed the Beats Audio speaker grill was removable, but since it could not be popped through from the inside I needed to make sure before using a sharper spudger to remove it. I appreciate the timely response!
tarafından
Yorum Ekle
Yanıtını ekle
chazdevereaux sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 192
