My lens will not retract when turned off.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
abcagle most commonly caused by a stuck lens. You should try the “tricks” mentioned on here. If that won’t work it is most likely that the lens is failing. You may need to either disassemble it and clean and inspect it, or replace it.
Ultimately it is also possible to replace the lens. Follow this guide Sony Cyber-shot DSC-W55 Lens Replacement
Bu yanıt yardımcı oldu mu?
Gelecekteki Onarımlar İçin Hazırlanın
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 522
