Ana içeriğe geç
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
20 Soru Tümünü görüntüle
Super stripped pentablobes screw
I’ve tried the tape, solder, rubberband, flathead screwdriver method. nothing works and I’m getting desperate. I don’t have a screw extractor
the two screws are full circles
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
please help me
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
What is the reason to open your iPhone ?
Does the screw turns, that means that the legs from screen have broken and that the screws won’t come out (then you can lift the screen and work from the inside), or doesn’t it turn and it stick on it’s place? Have you tried super glue? If that doesn’t help then you have to drill it out.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
my screen is broken so I need to change the screen (not cracked full dead screen). the screw doesn't turn, I'm looking for a drill bit but that's my last resort
tarafından
Yorum Ekle
I have had this issue on multiple occasions. Even after trying all of the things you have listed and more I have found a solution which is my go-to in situations like this and has gotten me out of sticky situations multiple times.
You need to get the ifixit driver bit in a flathead size 1. I have tried so many other flathead bits without any success and this one seriously is a god sent! Even when it is completely rounded off, I have found this will remove any pentalobe with the right amount of pressure.
Can be purchased here:
https://australia.ifixit.com/products/ma...
Good luck!
Puan 1
Yorum Ekle
Yanıtını ekle
Ean Palacios sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 83
