Ana içeriğe geç
The PowerBook 5300 is a 10.4 inch Apple laptop running on Macintosh System 7. It was the first to use the Power PC architecture.
Repairing power connection , intrenal
When power cord is connected,no power ,green light does not go on.
Is there an easy fix to this or must I re solder ,on interior of book.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
IIRC that model had known problems with the battery and the power connector. Check the cord with a multimeter to be sure its providing voltage to the computer. If it is you will need to check out and quite likely need to repair or replace the power connector. I am including a link to the guide that comes closest to assisting you with disassembly. Good luck.
Apple Powerbook 5300 Hard Drive Replacement
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
Douglas sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 868
