Ana içeriğe geç
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
20 Soru Tümünü görüntüle
MacBook Pro 15" Mid 2015 - Screen Hinge super stiff
Can anybody help me to solve this issue on my Macbook Pro? To open it I must apply a lot of strength and the lid won't open up without lifting the base (can see at 0:09 seconds at the video). It seems that the screen hinges are really tight. Also there is this sticky sound that seems like the rubbers along the screen are sticking to the body (noise happens at 0:06 at the video below).
I recorded a video and uploaded on YouTube:
https://youtu.be/Rw2zMXu7NH8
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I’ve had the same problem. I’m no expert but I saw a description of a likely solution to this problem and decided to try it myself rather than pay the exorbitant fees that repair shops proposed. An authorised Apple service centre even told me I had to change the lid/screen !!!
Preparation: I bought a pc tool kit on Amazon [£13]. I also got a small tube e.g. small straw or the inkiness portion of the ink tube in a biro. I sprayed a little WD40 into a egg cup [so it was 1-2mm deep].
I shut down the MacBook and removed the power cable. I then placed the MacBook top down on a towel and removed the screws holding the base in place. I then carefully prised the base from the rest of the MacBook, thereby exposing the lid hinges. I dipped one end of the tube into the WD40 and placed my finger over the other end of the tube so as to hold a drop or two of the WD40 in the tube as I lifted it away from the pool of WD40. I then very carefully placed the one or two drops of WD40 onto the lid hinges being careful not to apply too much WD40 [you only want enough to soak into the hinges and definitely not so much as to have WD40 anywhere else inside the MacBook]. I then replaced the base onto the MacBook and fitted its holding screws.
I then placed the MacBook on my lap as normal and carefully opened and closed the lid/screen to help the WD40 work its way throughout the internals of the hinges. Within seconds the lid/screen was opening and closing as normal.
Note that I am not a Apple/PC expert and I cannot guarantee that this solution is perfect in every way but it worked and I believe it’s a reasonable solution provided you take great care to ensure that only sufficient WD40 is applied to ‘wet’ the internal of the hinges. It’s important to avoid excess WD40 inside the MacBook casing.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I did exactly the same and it helped perfectly. Besides stiffness, my other problem was, the lid was not closing totally (would stay a few millimetres off the keyboard base, preventing the magnetic closing catch). This problem was fixed, too.
tarafından
Thank you, Peter Harraghy & F Uğurel !!! Just the tiniest drop of WD40 (in my case, CRC), and both the stiffness and not-closing-totally problems were instantly solved!
tarafından
Yorum Ekle
Yanıtını ekle
Arthur Viana sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 443
