Ana içeriğe geç
VLT 1000 masa vantilatörü, 30 cm çapında dört kanada sahiptir. Paslanmaz çelikten üretilmiştir ve 3 hız ayarı bulunur.
Fan speed slow initially
I have a tower fan which initially runs on low speed and after 20-30 min the speed becomes normal. What could be the reason and how to fix the issue?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum
Hi,
Does it run on low speed even if a higher speed setting is selected when starting?
Do the fan blades rotate easily and smoothly if you spin them by hand? (disconnect the power from the fan before you try this)
tarafından Paylaş
Its at first two speed. At third (highest) speed, it functions well. Yes, the blades rotate easily and smoothly if I spin by hand.
tarafından Paylaş
Can you run the fan at highest speed first for 2-3 minutes then switch to low speed? Tell me if that works or not :)
tarafından Paylaş
Bahut slow slow chal raha hai
=== Update (08/29/23) ===
Bahut slow slow chal raha hai friend
tarafından Paylaş
Fan slow problom
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@ sachin gupta
What is the make and model number of the fan as you have selected a desktop fan as the device and not a "tower fan"?
If the fan is no longer under warranty, you may have to open the fan and access the control board where the speed buttons are connected to and check the components. Usually with speed controls for fans, the switches connect or disconnect capacitors into the fan's motor circuit to increase / decrease the amount of current flowing to the motor so that it runs faster or slower.
If you see any problems or if you're not quite sure, post some images back here.
Here's how to do this Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
sachin gupta besides the great suggestions given by @jayeff it is also possible that your fan motor is most likely starting to gum up. I suggest you tear it down right to the motor teh clean the rotor shaft bearing etc. with some contact cleaner/degreaser and some good puffs of compressed air. Dry everything off and apply some grease to the bearings etc.
It is also possible that the motor windings are starting to fail.
Puan 1
Yorum Ekle
Please check the capester is fully fit or not and maybe the fault is in her capester because nothing that powers the fan
Puan 0
Yorum Ekle
Yanıtını ekle
sachin gupta sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 31
Her zaman: 2,435
